Centerforce DF clutch, what size?
Hey all, I am about to order a centerforce DF from Summit. I have a 72 vette, 383 stroker engine with a 400 flywheel 4 speed M21 transmission. Which one do I need?
GM: 11 in. diameter, 1 1/8 in. x 26 spline input shaft, Dual Friction clutch set
or
GM: 12 in. diameter, 1 1/8 in. x 10 spline input shaft, Dual Friction clutch set
Thanks!
or
Thanks!
Re: Centerforce DF clutch, what size? (mpro72vette)
11" :yesnod:
:steering: 11", but you need to look at the trans and make sure it is the 26 spline imput and not the earlier 10 spline.
Hope this helps.
Terry
Hope this helps.
Terry
On my bigblock I want to run the 11 inch clutch so i had to find a 14 inch flywheel. It requires a larger bellhousing then most so I go it off a truck. Is there a 12 inch clutch? My pressure plate for the 11 inch clutch fills out the flywheel completely. How would a 12 inch clutch fit? It is impossible to go to a bigger flywheel. :)
