I found a bad lifter when I was changing the Intake manifold.
The last time I changed the oil I found what looked like a piece of a small clip. I thought it looked like the clip that holds the top of a lifter in. Sure enough when I pulled the intake and took a look I found a lifter with a missing clip. I removed it and installed a clip from an older lifter that I had and all seems well so far. Has anyone had this problem and what could have caused it. I never had any tapping in the engine and it ran well. :confused:
Re: I found a bad lifter when I was changing the Intake manifold. (vettfixr)
Did you test the plunger to see if it still floated? Maybe it was frozen or became twisted. If not, then I would say you were lucky. Sustained high rpm’s could have resulted in one of those ‘expensive mistakes cause by failure of a 1-cent part’.
I replaced the wire clips with internal snap rings when I installed new lifters. They are not subject to significant load, but assembly is much more repeatable and reliable.
Re: I found a bad lifter when I was changing the Intake manifold. (Turbo-Jet)
Did you test the plunger to see if it still floated.
St. Jude Donor '09
That can happen when there isn't enough preload on the lifter and the plunger hammers the clip out :cheers:
Re: I found a bad lifter when I was changing the Intake manifold. (yellow 72)
