Longer spindles and Roll Center
I have been looking at correcting the problem of my front wheels going into a positve camber when it should be going negative. The front suspension was designed in the '50's when tire technology was so poor that they designed in positive camber to keep the tires from coming off the wheel in a corner (think leaning to the outside when turning). Well, tires have vastly improved and will keep getting better (carbon nano-fibers are coming to a tire near you soon!), so now is the time to correct this built in deficiency. Except for you dinosaurs still running 15 inch wheels - you guys are hopeless!
Anyways, there are two ways to do this. Lower the inner mounting point of the upper A-arm (drilling new holes in the frame-OUCH - but popular in the 1st gen camaro crowd) or extending the upper part of the spindle. Well, I found several ways to do the latter fairly easily and will probably be looking at one of the coleman adjustable ball joints modified to fit my A-arm. I must say the I am REALLY suprised that VBP hasen't jumped on this, but it may be outside their ability to properly evaluate.
http://www.colemanracing.com/section/index.htp?id=1191 http://www.colemanracing.com/section/index.htp?id=617</A> http://www.colemanracing.com/section/index.htp?id=629 http://www.colemanracing.com/section/index.htp?id=630
These are bolt on, but arent adjustable and are a little pricey. http://www.drgas.com/promotor/spindleex.html http://www.hotrod.com/howto/50358/index.html
And here are some excellent articles on determining roll center and other critical front suspension geometry.
http://www.circletrack.com/howto/1816/index.html http://www.circletrack.com/techarticles/4637/index.html <A HREF="http://www.circletrack.com/techarticles/0304_meas/index.html" TARGET="_blank">http://www.circletrack.com/techarticles/0304_meas/index.html
Any thoughts are welcome, except for personal attacks (tho I expect the dinosaur comment deserves a fair response)!!!
Chris
Chris
Re: Longer spindles and Roll Center (71roadster)
Chris,
I have been following similar topics for my Camaro. As you said, many people redrill the upper mounting holes using a template made by Guldstrand. This mod would work in the same manner as it does for the Camaro. I just received the Camaro suspension geometry, and will be working with it. The next step will be with the Vette suspension. (The Camaro needs it more.) I haven't looked into the spindle, but keep us posted.
Ken
Ken
I'm glad to see you posted this. Alot of the information you posted I have read before in magazine articles but have been unable to find them. You sent them to me in one neat package.
Thank you Chris
Thank you Chris
After you do yours I will want a ride. then maybe it will be time to tear down my front suspension and go with the trick upper a-arms as well. :)
-terry
-terry
Re: Longer spindles and Roll Center (terryrudy)
you better wear diapers! With all new front suspension/steering on top of the 383 and TKO, we're both gonna need some depends.
Chris
soon, sort of soon...
Chris
Location: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
Norval and I talked about this earlier. Since that time I have lost my archives of info due to the great Trojen Worm of '03. So thanks for sendiing me the information as I needed it too.
I think the ball joint I chose was from Speedway. It was a Moog joint that they carry. It does require a redrill of the control arm but that is no problem on my tubular upper A-arms. If there is a better one please let me know.
I do have one question though, What was it I read about using an offset upper control arm shaft to set the A-arm back without drilling and relocating it to help with adjustments of the camber? Would this help or even be necessary?
Jim
Jim
I remember Norval mentioning this a bit back, but I could never find the item on Hot Rod's site. Thanks for the link to the article and the manufacturer.
I remember reading somewhere that VBP control arms have a different geometry to correct for some short-coming of the stock system. Anyone remember what it was? Could it be that they lengthened the lower arm compared to the top to increase the tendency toward neg camber? I would be curious if the spindle extender would be useful for both the stock stamped arms and the VBP arms. I believe I read in your sig that you have them?
St. Jude Donor '05
Re: Longer spindles and Roll Center (75 BBC Stingray)
Mine have no ball joints. They are new but I bought them off of the net second hand. I only have the upper tube A-arms at this time. I am purchasing either the transverse set-up or 550# springs to go with these.
OPINIONS? Jim
OK......................I'm Lost......HELP? Does this mean I do or do not still need the extended Ball joints? JIM
Re: Longer spindles and Roll Center (Turbo-Jet)
The VBP A-arms simply relocate the upper ball joint a bit further back, increasing caster. The increased caster will only very marginally reduce the camber but I suspect it is still in the positive zone when compressed, and we want to be negative on the outside wheel (tilted in at the top) in a corner. And as for adding camber in static position, that is a bad way to solve the current problem.
The extenders wont affect the caster at all.
St. Jude Donor '08-'09
this is the simplest way to determine RC
:cheers:
I think 2-3 inches above the road is a good target. There are a couple of good books on this subject, you should have at least one if you are going to monkey around with the car's geometry. Joe
Does anyone have any idea where an ideal static roll-center should be?
Chris
Chris
:yesnod:
[Modified by Turbo-Jet, 3:49 PM 2/25/2003]
Re: Longer spindles and Roll Center (e3pres)
That way is valid if the car is at rest. To determine roll center at various points in suspension travel (i.e. During cornering), draw the instant centers for each side. Connect the each instant center to the centerline of each tire (R to L, and L to R). Where the two lines intersect is the the roll center for that specific instance.
:cheers:
:cheers:
