Converting from a Q-Jet to Hollet 3310,need suggestions on brackets.
The throttle cable on the Q-Jet is mounted to a bracket that mounts to the rear two carb mount bolts,and I'm sure the Holley won't allow that type of bracket. I haven't baught the carb yet,thaught I'd order everything I'll need at once. What type hardware will I need to mount and hook up all throttle,kickdown,fuel lines,manual choke cables,etc.
I have a general idea,what I need,I'm just looking for ideas or pictures of a clean 3310 install.(I hate rigging.)
Re: Converting from a Q-Jet to Hollet 3310,need suggestions on brackets. (The Money Pit)
I think your original bracket will work. But if you are looking for an adjustable cable bracket Summit has one for $ 8.99 G1414. This is the one I am using on my 74 with a Holley DP.
Ed
Ed
