Is the breather necessary?
I'm using a set of aftermarket valve covers on my 69 coupe. PCV is on one side and the breather is on the other. My problem is that oil oozes from the breather onto the valve cover.
The original set of valve covers did not have a breather, just oil filler and PCV. Since having the motor rebuilt, it was necessary to add a set of high rise valve covers to clear the roller rockers....Anyway, is the breather really necessary or can I just plug it up?
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: Is the breather necessary? (Michaeljh2000)
Yes, the original didn't have a breather, but it did have a pipe that went from the valve cover into the aircleaner that did the same job.
Not running a high rise but, do have aafter market. The breather has a baffle under it so it doesn't through oil into the breather. :seeya
Re: Is the breather necessary? (wartosh)
Add a baffle at the opening??...Great idea!! My buddy Steve said the same thing, only I was curious if I could just plug the hole. Thanks
