Can someone post a picture of a vacuum modulator for a 1980?
I am trying to locate the vacuum modulator on my 80's auto tranny to see if its either bad or leaking vacuum. I was told that its located on the passenger side of the trans just above the pan gasket towards the front. I looked but can't seem to locate anything that might be it. Thanks guys!
:confused:
:confused:
Re: Can someone post a picture of a vacuum modulator for a 1980? (Fasteighty)
Fasteighty,
I sent you an email (to the address in your CF profile) with the page from my assembly manual showing the transmission with the "modulator pipe" and what looks to be the vacuum modulator that you're talking about.
I hope this helps.
Matt
I hope this helps.
Matt
Sorry the pic is kinda blurry but it should suffice. The smaller one on the left is the replacement adjustable type. The larger one on the right is the factory installed unit from our 73.
