What does Grandsport use for lights?
Hey GrandSport,
I am considering putting my headlights in the area where the grills and turn signals are located. Did you use a kit or is that a custom installation?
Location: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
Re: What does Grandsport use for lights? (79VetteMike)
I'll give you a suggestion to use.
An early '90's Pontiac Grand Prix or a Camaro. They use the little sealed beam light set with a module to contain them. The GP are individual pods and the Camaro is a single pod containing both hi & Low beams. The Camaro is made at an angle. It may correspond with the Vette better, you will have to look at both to see which suits it best.
This style of light is self contained in its pod. This means that the pod contains all adjustments and even a level built in. All you have to do is bolt it in and wire in the plug. Another advantage is that they are very small and may blend better with the front of the vette.
I used the low beam from a GP to make running lights in my Jeep Cherokee winch bumper. Two screws and a wire in and I was ready to adjust the lights. JIM :smash:
Re: What does Grandsport use for lights? (PROSOUTH)
79MikeVette. My .02 your car looks great just the way it is. Your pop-up lights are the nicest part of that. I can't count the amount of molded over front ends that the body work was flawed or just looked bad. Hopefully yours comes out great and makes you happy, that's all that matters. But take a look at one of those conversions in person before you start ripping out or molding over those pop-up headlights. Again just my .02, good luck.
David
David
Location: The cure for the blues is eight cylinders roaring
Re: What does Grandsport use for lights? (Cali,77,L-82)
I figured out that the head lights and bezals came from a 75 or 76 Caprice.
He bought the car with them on. I believe they came off of a mid 70's Caprice or something. There was a thread about it a while back. What is sad is that I can remember all of this.
St. Jude Donor '09
Re: What does Grandsport use for lights? (Schmucker)
BTW I remembered this too, you guy's just posted it before me.... :thumbs:
Hey GrandSport,
:cheers:
Olivier
