Do locking rocker arm nuts fit under stock valve covers ?
I have LT-1/L-82 valve covers. Do the aftermarket locking rocker shaft nuts fit under these valve covers ?
Re: Do locking rocker arm nuts fit under stock valve covers ? (dman535)
I have a set of Crane Kool nuts on mine. These are locking nuts. I have to use the thick Fel pro valve cover gaskets. Actually have a metal insert between two gaskets. These work very well. I had to mill the drippers to 1/2 height due to the lift on the cam but other than that I have stock valve covers.
Re: Do locking rocker arm nuts fit under stock valve covers ? (Gordonm)
Any idea on centerbolt covers ? what p/n felpro gaskets are you using ?
