HELP!!!! Who knows how to remove silicon gasket material?????
Old 02-21-2003, 11:09 AM
chadman
chadman's Avatar
Default HELP!!!! Who knows how to remove silicon gasket material?????
Bubba glued my weatherstrip with silicon. It didn't stick to the rubber but sticks like heck to the body. Anyone have any neat tricks to clean it off????? :confused:
Old 02-21-2003, 11:59 AM
burners
burners's Avatar
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: HELP!!!! Who knows how to remove silicon gasket material????? (chadman)
Depending on the type of silicon used ammonia works well. Usually the strength on glass cleaner is good enough but you may want to try mixing your own. It won't take off the big chunks but it works well on the small or thin areas. Good luck, that stuff is a real pain.
Old 02-21-2003, 02:45 PM
mrvette
mrvette's Avatar
IFyou are talking Silocone sealant like RTV, maybe the blue/red/orange/gold/blacks made for auto use, comes in toothpaste tubes...
the solvent is mineral spirits...but use a razor blade first....
I follow up with carb cleaner afterwards......but watch the paint....
then go for glass cleaners....
when the stuff is fresh, and you are doing a cleanup after an install...
use denatured alchahol.....
GENE
Old 02-21-2003, 03:04 PM
chadman
chadman's Avatar
Default Re: HELP!!!! Who knows how to remove silicon gasket material????? (mrvette)
Thanks guys!!! Mineral spirits, eh. I know trying to just rub or scrub is the pits.
Old 02-21-2003, 03:22 PM
mrvette
mrvette's Avatar
chadman, what is your opinion of the rack/pinion install??? driven it yet???
GENE
Old 02-21-2003, 03:57 PM
Paul L
Paul L's Avatar
Silicone seal remover is available at any hardware/plumbing store. It is used to clean up sealed areas such as the joints in tub surrounds.
To HELP!!!! Who knows how to remove silicon gasket material?????
Quick Reply: HELP!!!! Who knows how to remove silicon gasket material?????
