new guy here...
Navigator
new guy here...
hey, I have a navy blue corvette, you can see a picture of it here http://www.angelfire.com/hi5/firebird but i want to make it decently fast by putting a cam and heads, maybe some nitrous or something of the sort, my dad had the engine rebuilt and it only has about 500 miles on it, if that many and has just been sittin in our garage so ive actually worked on it all last summer and made it driveable, now its on to the performance stuff. so if anyone has any suggestions or experience with this, any info will be appreciated.
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '03
Re: new guy here... (SIGNGUY)
Welcome to the forum! :seeya
Dave
Dave
Re: new guy here... (18withan81)
Welcome !!
It's tough to recommend tearing a fresh rebuild apart, but I think you are
definitely going to see some 'go' from new heads and cam.
If you can get away (inspection) with a true-dual exhaust, you should get
a seat-of-the-pants improvement with that - and no engine tear-down.
Also new rear-gears can help to multiply the torque up - but that can be
a job that no-one wants to get into. Removing the rear suspension for the
first time SUX.
I'd say keep reading here - and posting your ideas. The folks here will
help to guide you down the twisty (but fun) road.
Good Luck :seeya and stick around :seeya and don't forget to wave :seeya
first time SUX.
First of all, welcome to the madness, er uhh I mean the forum.
Second, nice vette!!!
Now then, I will say this. If you are still using those Eagle GT's that are on your car, they are probably close to 16 - 20 years old. Be careful on those old tires. I have a set of them in my attic... put some new 255/60/15's on last year and couldn't believe how much better the car drove.
If I am wrong, and you bought those tires new recently, where did you get them? I want another set!!!!!!!!
Blowers or nitrous requires the use of forged rotating parts for reliability. Do it wrong and you can convert that fresh 500 mile rebuild into scrap in another 500 miles or less.
For heads, I'd consider the Sportman II's if cost is any issue. As far as a cam, I'd consider your compression ratio & rear gearing when choosing one :yesnod: . I'm assuming you have headers on your car as it's not worth getting more air into your engine if you can't get rid of it ;) .
And welcome to the forum :seeya .
Nice looking car, glad to have you here with us. What is your goal for power output and what is your budget? If you need to go cheap you can port the heads yourself (that will get you maybe 30hp) and then swap the cam. Or you can get some World Products Sportman II's or Dart Iron Eagle's for around $700 or 800. Those should be worth 30 to 50 hp. Swap the cam as well.
