The following oil companys DO NOT obtain oil from Middle East.
Citco, Sunoco, Conoco,Sinclair,BP/Phillips Hess, obtain oil from other than the middle east, :thumbs: I am immediately buying fuel from the above mentioned dealers. :rant: only, :thumbs: if everone was aware of this info ,we wouldnt need middle east oil & they could eat sand. :U the rantings of the Dog...Woof Woof. :steering: :flag
Re: The following oil companys DO NOT obtain oil from Middle East. (StrayDog)
Not all true but it seems Hess might be the best choice for you:
http://www.snopes.com/inboxer/outrage/nogas.htm
http://www.snopes.com/inboxer/boycotts/hess.asp
Cruise-In VI Veteran
Cruise-In VII Veteran
I think that list is suspect to closer scrutiny. My son works for Conoco/Phillips (they merged last year) and I know that they have production facilities in the Mid-East.
The world oil market is pretty much a wide open commodity market, where traders that work for the oil companies bid on oil and natural gas from whoever they can get the best spot prices from. It's all in one big pool.
Trying to isolate which companies use Mid-East oil and not buy from them is sort of like trying to not breathe air that came from the Mid-East. It's a nice idea and I wish there was someway of punishing them by not buying their oil, but it just can't happen until everybody quits using fossil fuels.
Besides, I've yet to see one of those anywhere in the western states - certainly not in Southern California. Also if they acquired oil from venezuela then you can be certain they are getting it from somewhere else right now, the most likely culprit being mexico or the middle east.
CI 7-8 Veteran
Re: The following oil companys DO NOT obtain oil from Middle East. (Fevre)
Hey, that's cool cause I work for Hess. I'm actaully in Western Africa right now about to go out to one of our rigs and it is like nowhere else I've ever been before.
Re: The following oil companys DO NOT obtain oil from Middle East. (Smokehouse69)
i know i have an anti middle-east-air filter :D
Location: The reason time exists is so everything doesn't happen at once
Re: The following oil companys DO NOT obtain oil from Middle East. (tshort)
Smokehouse69 is right, oil is oil and the commodities markets make it almost impossible to tell where it really comes from. Unless you can tap into a Texas oil field or the Alaska pipeline and refine it yourself you have no way of knowing the ultimate source.
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Re: The following oil companys DO NOT obtain oil from Middle East. (6t9l4t6)
Even gasoline in the distribution lines is all mixed. Each company puts in x number gallons at one point, and pulls out x number gallons at the other side. They are not getting just their gas, but what ever gasoline is closest to the taps. It could be any companies gas at that point.
From the local side they pull out the gasoline and then add "their" additives to it as they put it into local storage and into the trucks for distribution locally.
No offense intended, because I know this was posted with good intentions, BUT...
Conoco merged with Phillips, BP bought Amoco, so there are already holes in this story.
The other thing is, as posted already, nearly every oil company in the world buys oil on the open market to process in their own facilities. The interesting thing about this is that BP doesn't necessarily process their own oil...their facilities are buying oil from whoever is cheapest, so if BP is higher they won't even buy their own oil. The fact is that we produce about 1/3 of our own oil. If you plan to cut your oil/gasoline consumption by 2/3, along with everyone else in the US (yeah, right!) then this MIGHT be plausible.
When you let us start drilling off the coast of Florida, California, and in Alaska maybe then you can point fingers at oil companies who buy overseas oil.
But when you think about it, why not use up the foreign oil? There is a limited amount of oil on this planet (although we keep finding more and more as the technology matures). Use up their oil now, and we will really hold the cards when/if ours is the primary/only petroleum left in the world.
Think about all this for awhile...then go do a smoky burnout, just because you can!
Jeff
Jeff
Re: The following oil companys DO NOT obtain oil from Middle East. (no_radio)
But when you think about it, why not use up the foreign oil? There is a limited amount of oil on this planet ... Use up their oil now, and we will really hold the cards when/if ours is the primary/only petroleum left in the world.
[Modified by Smokehouse69, 11:23 PM 2/19/2003]
As long as gas is still cheaper to buy than bottled water there is no real incentive to move away from our reliance on Middle East reserves, and continue to develop better alternative sources of fuel. It bodes for an interesting and expensive summer of cruising.
...I wish there was someway of punishing them by not buying their oil, but it just can't happen until everybody quits using fossil fuels.
I also recieved an e-mail about this awhile back. BUT, I know locally, we have a "tank farm"(gas storage depot), and the semi trucks load up there, and then deliver the SAME fuel to ALL the different stations. My best friend used to drive a fuel truck from there, so that's where I got my info.
