The list of wheels for a C3.............
For all the guys who saw my post about creating a list of wheels for C3's, here it is. It's still rough and many other wheels probably can be added. Let me know about any changes that are neccassary/or any suggestions :cheers:
Wheels For C3 Corvette’s
ATTENTION: This is just a reference guide with wheels that are known fit C3 Corvettes. Others sizes of these wheels may also fit. None of the information below is a 100% sure thing, and I take no responsibility for wheels that do not fit someone’s car. If you see any mistakes let me know so I can change them. All corvettes have a factory 5x4.75” bolt pattern, which all of these wheels should have available.
Direct Bolt-ons
1. American Racing Torq Thrust II’s
Sizes--16”x8”, 17”x8”,
Backspacing-- 4”
2. American Racing CP200’s
Size--15”x8”
Backspacing--4”
3. Edelbrock 409’s
Size--16”x8”
Backspacing--4”
4. American Racing 136’s
Sizes--15”x8”
Backspacing--4”
5. American Racing CL205’s
Size--17”x8”
Backspacing--4”
6. Wheel Vintiques Steel Rallies
Size--17”x8”
Backspacing--4 1/8”
7. American Racing 200S
Size--15”x8”
Backspacing--4”
8. Eagle Alloys Series 117
Size--15”x8”
Backspacing--4”
9. Corvette Rally Wheels
Size--15”x8”
Backspacing--4”
10. Corvette Aluminum Wheels
Size--15”x8”
Backspacing--4”
11. Performance Wheel Outlet’s Vortec Z
Size--17”x8.5”
Backspacing--4”
12. Centerline Galaxy Series
Size--17”x8”
Backspacing--4”
13. Centerline Autodrag’s*
Size--15”x8.5”
Backspacing--3.375”
*May stick out slightly without larger fender flares
14. Boyd Coddington Genesis 5
Size--17”x8”
Backspacing--4”
15. Boyd Coddington Timeless 5
Size--17”x8”
Backspacing--4”
16. Centerline Meteor
Sizes--17”x8”, 17”x9.5*
Backspacings--4”, 5”*
*The 17”x9.5” with 5” backspacing will fit on the rear if the e-brake is moved
17. American Racing Torq Thrust D’s
Size--17”x8”
Backspacing--4”
Wheels That Require Modification, Spacers, or Adaptors
C4 Corvette Wheels
Size—17’x8.5”, 17”x9.5”
Require adaptors that can be bought from Vette Brakes
Cragar S/S
Size--15”x8”
Backspacing--4”
Require a spacer to fit
Eagle Type 77
Size--17”x9”
Backspacing--unknown
Require a 2 ¼”spacer from Vette Brakes to fit
Weld Draglites
Size--15”x8” front, 15”x9” rear
Backspacing--4 ½ front, 5 ½ rear
Require a 1 ¼” wheel adapter from Vette Brakes for the rear, front requires ½” spacer
[Modified by Ryan77, 6:29 PM 2/23/2003]
Direct Bolt-ons
Backspacing-- 4”
Size--15”x8”
Backspacing--4”
3. Edelbrock 409’s
Size--16”x8”
Backspacing--4”
Sizes--15”x8”
Backspacing--4”
Size--17”x8”
Backspacing--4”
Size--17”x8”
Backspacing--4 1/8”
Size--15”x8”
Backspacing--4”
Size--15”x8”
Backspacing--4”
Size--15”x8”
Backspacing--4”
Size--15”x8”
Backspacing--4”
Size--17”x8.5”
Backspacing--4”
Size--17”x8”
Backspacing--4”
Size--15”x8.5”
Backspacing--3.375”
Size--17”x8”
Backspacing--4”
Size--17”x8”
Backspacing--4”
Size--17”x8”
Backspacing--4”
C4 Corvette Wheels
Cragar S/S
Size--15”x8”
Backspacing--4”
Eagle Type 77
Size--17”x9”
Weld Draglites
Location: If you can read this, thank a teacher. If it is in English, thank a veteran.
Cruise-In IV Veteran
Cruise-In V Veteran
Re: The list of wheels for a C3............. (Ryan77)
Great start. I would love to see pics of the wheels and tire sizes too. Also, Cragar SS 15x8, 4" backspacing fit with a spacer. My tires are 235R60/15's. :cheers:
Re: The list of wheels for a C3............. (L48Shark)
:cool:
Maybe once this list is near complete it could be written into a tech article.
What no pics of each ( on the car with different angles please) :jester
Nice work, many will benefit. :cheers:
Cruise-In IX Veteran
Re: The list of wheels for a C3............. (n8370c)
http://www.corvettefaq.com has a wheel sections with pics of some wheels on cars.
Re: The list of wheels for a C3............. (Sigforty)
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Do you direct fit only, or are you interested in adding a section of newer C4 and C5 wheels that will work with adapters?
My 1980 has 1996 wheels (17x8.5 and 17x9.5) that fit very nicely with adapters from Vette Brakes.
Re: The list of wheels for a C3............. (BSeery)
I'm adding ANY wheels that can fit on a vette, mods or not. I have the C4 wheels at the bottom of the page in the "mods required" category :cheers:
Re: The list of wheels for a C3............. (Metal_Wulf)
cool list :cool:
:thumbs:
:thumbs:
[Modified by GrandSportC3, 2:42 PM 2/19/2003]
Location: The cure for the blues is eight cylinders roaring
Re: The list of wheels for a C3............. (1bad69)
This is Centerlines Meteor wheel part of the sundance series you can get it in allmost any width, diamiter,backspacing or five lug pattern you want. My rears are 17x9.5 with a 5in. back space but the E-break does have to be moved. I'm ordering 17x8 with a stock BS for the frount.I should have them on this spring.
:cheers:
[Modified by PrarieShark, 3:08 PM 2/19/2003]
[Modified by PrarieShark, 3:14 PM 2/19/2003]
:cheers:
Deleted 2nd post :smash:
[Modified by PrarieShark, 3:11 PM 2/19/2003]
Good Show , Ryan.
Somewhere in the archives is a "Wheel and Tire Weigh In" that I wrote a couple of months back. For performance, total weight of wheel and tire should be considered as well as fit and appearance.
Re: The list of wheels for a C3............. (flynhi)
I added a couple new ones, keep 'em comin :cheers: . Let me know what you guys are running for tires (post them here or IM me) :thumbs:
Does anyone know the name of the forum member with the green C3 that has the Cragar S/S Series 61's on it :confused:
is backspacing the depth between the outer face of the wheel and the center where it bolts to the vehicle?
