Pwr window Power wire question
With help from you guys on the forum I found that the mystery orange wire with the black stripe was the hot lead that runs from the pwr window relay to the fuse panel. Now my question is where does it plug into the fuse panel at? I have looked at the panel and there is nothing marked for pwr windows. I do se several empty accessory outlets. The wire has a round eye connector on it so I am thinking that at some time this was added and the wire might have been run to another switched power source. Is there anther connector I need to use to plug this thing back into the fuse panel? Thanks for the help. :cheers:
Re: Pwr window Power wire question (BlackRat)
I think this link might have the info you need.
http://www.corvetteforum.net/c3/tune.../index22.shtml
