Will a TH350 yoke fit in a 700R4.
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: Will a TH350 yoke fit in a 700R4. (Budman78)
Buddy, I think the TH200-r, TH700r4, Powerglide and TH350 all have the same yoke. The TH400 is the odd ball of the lot.
Cruise-In III Veteran
Re: Will a TH350 yoke fit in a 700R4. (Smokehouse69)
:withstupid:
I've been doing some research on yokes, since I'm looking at doing a 200-4R conversion to my '73 (which has the stock TH400.) The TH400 has 32 splines, while the 700-R4, 200-4R, TH350 and Powerglide have 27 spline output shafts.
If anyone is interested I have a brand NEW Corvette style (strap w/bolts type) trans yoke that takes you from a small output shaft to the larger (late model) u-joint. if anyone is looking you can e-mail me direct!! redvetracr@msn.com
