How much HP/torque will a stock TH350 handle?
I'm going to do a 383 before too long and wanted some ideas on how much HP/torgue a stock TH350 will handle. I'm going to end up with about 400hp and 450ft/lbs and don't want to destroy the tranny.
Re: How much HP/torque will a stock TH350 handle? (914eener)
:cheers:
Olivier
My rebuilt 350 tranny with QS kit did not stand up to the 355HP/405 ft-lb ZZ4 engine and showed significant metal shavings in filter. I dropped in a 700R4 with OD and QS to be sure.
I had a 383 in my old corvette that was in the neighborhood of 425 ft/lbs torque and my th 350 gave no problems.
one thing I would highly recomend is getting a shop to go over it to make sure it is in top shape then install a shift kit B&M or trans pak and I would also install a Trans temp gauge if your are going to be doing alot of racing just so you know whats going on inside there HEAT KILLS AUTOS.
I was going to change out my auto for a 4 speed untill I Rebuilt the Auto and now I won't go back .
best of luck
TTFN
best of luck
TTFN
Cruise-In VII Veteran
St. Jude Donor '07
Re: How much HP/torque will a stock TH350 handle? (Aaron76)
I shot over 450 pounds of torque to mine and it had no problems, but that was on street tires. :crazy:
