i am getting ready to install my new dewitts aluminum radiator. what to fill with?
i want to use royal purple but i dont want to use the hard tap water. is it better to use distilled water?
thanks,
Mike
thanks,
Mike
Re: aluminum radiator. what to fill with?
Equal parts of distilled water and your favorite antifreeze. I like Preston(greeb stuff) for our older cars and the Havoline Extended Life(orange stuff) for my newer cars.
Gary
Gary
i am getting ready to install my new dewitts aluminum radiator. what to fill with? (Michael Tucker)
Fill it up with distilled water first, and check for leaks etc. That way if there is a problem you don't have to worry about dumping the royal purple or recycling. If everything checks then re-fill 50/50.
mark
mark
Even though the radiator is aluminum you definately want to use distilled water. It's available at any major grocery chain for about a buck a gallon. To make a 50/50 mix with the green stuff it will take a little less than 2 gallons fo the initial fill.
Are you also changing the water pump for a high flow unit? I used the Stewart stage II when I installed the same radiator and love it.
Re: (zwede)
I'm also a fan of Dex Cool The first year I had my new aluminum rad I filled it with a 50/50 mix of prestone, the green stuff and after a year the inside of my new aluminum rad had a white deposit all over the inside. I switched to dex cool and the film disappeared and the inside looks totally clean.
