Low brake pedal problem?
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Oldtimer
I recently replaced all four calipers and the master cylinder on my 79 and flushed the system but I still have a relatively low brake pedal. The brakes work fine and stop perfectly, but still I have this brake pedal that is low, anybody have any ideas why? :confused:
Re: Low brake pedal problem? (killain)
Does it get harder (or "less-low") as you pump it? Are you certain the system is completely & properly bled?
D. Ocean
Miami, FLA
D. Ocean
Miami, FLA
Oldtimer
Re: Low brake pedal problem? (74FLCONV)
Yes I'm pretty sure it's bled properly. the pedal is hard as it gets down by the floor. Not on the floor but kinda close.
