RPM Air Gap ?'s
RPM Air Gap ?'s
I Keep seeing in the ads for this intake that it says that it will not fit stock corvette hood. What year are they talking about? I am lookinginto this manifold and i know that a number of you guys run these intakes.. what did you guys do to get these to fit, short of a different hood?
Re: RPM Air Gap ?'s (Aflac)
Clink is running an RPM air gap on his 383 small block and is running the stock '69 Corvette hood. Later model C3s without the wiper door actually have more hood clearence than those hoods on the '69s with the wiper doors.
You should be able to fit the RPM air gap with a drop base air cleaner. If you are using a drop base air cleaner you will also need to remove the choke tower off of your carburetor's primaries. The choke tower will inhibit air flow and you will be running to rich with the air cleaner in place. I had to do this with my Strip Dominator intake on my big block (run a drop base and remove choke tower).
I got a cheap drop base air cleaner from NAPA it's a Specter air cleaner (12" I believe). The air cleaner assembly cost me like $25. I will also be changing the elment over to a K&N air filter in the spring.
:cheers:
Olivier
guys,
you all kick major butt!!!! It never fails that when i have questions, you all make the answers seem so stupidly simple! i appreciate it! and grandsportC#, i am so srry for what heppened to your duntov.. i hope that i never have the disfortune to see mine like that.. i think i would prolly throw up afterwards
I have an RPM, not an air-gap though, under the stock '77 hood. I have a K&N 1 1/4" drop base with 3" filter. If you have to go with something like a 2 1/4" filter, then I would recommend getting the K&N extreme lid too :cheers:
:cheers:
Olivier
Yes, I fit the RPM Air Gap under a 69 SB hood. This is the lowest hood of all years I believe.. I used a L46 350/350 drop base, same as LT1 . It is a 2 " drop base. Used a 3"x14" K&N with Extreme lid. You will find the choke tower is way up in the top at this point, thats why I milled it off. No Choke, don't need it. Car starts in 0 degress easy. This will way out perform the standard Performer intake, It is really great around town. I have a previous post somewhere in the archives (gee as much as I am asked about this it should have its own link in the sidebar) :yesnod: , anyway, look for "RPM and how I made it fit" I think thats it...
[Modified by Clink69, 6:36 PM 2/13/2003]
