Which Speedo Gear for a 3:55 ?
I have it all setup for this weekend. 2 friends from my Corvette club will remove my stock 3:08 diff and put in a rebuilt 3:55. Rebuilt side yokes and mounting kit.
I know I have several color/teeth gears that I can install in the trans for the speedo cable but I dont know which one I need for a 3:55. This is such a simple thing to do. anybody know which one I need ?
The Chevy parts guy says I have these choices but he does not know which one I need.
18 Brown
19 Natural
22 Green
23 Black
24 Yellow
25 Orange
21 Red
22 silver
20 Blue
Thanks for your help
18 Brown
19 Natural
22 Green
23 Black
24 Yellow
25 Orange
21 Red
22 silver
20 Blue
Re: Which Speedo Gear for a 3:55 ? (Pete76Shark)
My car has a 3.55 rear and I have the 22 tooth green gear. Anecdotal at best, but I do know that my speedo reads correctly.
Shannon
Shannon
Re: Which Speedo Gear for a 3:55 ? (sb69coupe)
I did this change 4 years ago. You will need to change more than the gear on the cable. The new gear will not fit into the housing. I checked with transmission shops and a speedo shop and both told me you would have to change the gear inside the case as well. They do make a reducer/adaptor that would fit in the cable. It would have a short cable hooked up to the transmission that went to the adaptor and your cable would hook up to the adaptor and go to the speedo.
Thats what I was told.
From looking at the ZIP catalog it says I will need drive gear sleeve that matchs the number of teeth. I guess the pan has to be dropped to get to the gear and sleeve.
