1977 positraction ?
02-12-2003, 06:59 PM
1977 positraction ?
i have a 1977 vette that wheel spins only the right rear tyre,is this normal ?arent 77`s meant to have positraction which should eliminate one wheel spinning ? :crazy:
02-12-2003, 07:12 PM
Re: 1977 positraction ? (New-Zealander)
yeah, both should be a' spinnin :eek:
bad posi unit? check the fluid in the diff
02-12-2003, 08:08 PM
Re: 1977 positraction ? (flood)
If only one is spinning most likely the clutch pack is gone. Time for a rebuild
02-13-2003, 01:25 AM
Re: 1977 positraction ? (Gordonm)
Thanks for your help guys, much appreciated :cheers:
02-13-2003, 01:47 AM
I'd replace the fluid 1st - cheaper than a rebuild!
:cheers:
1977,
77,
clutch,
clutches,
corvette,
corvettes,
eaton,
flooded,
fluid,
packs,
posi,
positive,
positraction,
replace,
traction
