Which Steering Component Do I remove??????
I am going to replace the rear main seal in my 1981 stock 350 with auto tranny. Does anyone know which steering component I must remove to get the oil pan out? Is it the pitman arm or the steering ram cylinder?
Thanks in advance for any help. :seeya
Re: Which Steering Component Do I remove?????? (Richard Cooper)
The ram is easy to move.. Take it loose from the frame and then drop the long drag link. The pitman arm takes a special tool but you shouln't have to remove it.
Hello Richie-I think you can unbolt the idler arm at passenger side bracket, disconnect pitman arm from steering gear box, and steering linkage should drop down and swing out of the way enough to get oil pan down.
Re: Which Steering Component Do I remove?????? (silvervetteman)
Remove the nut on the idler arm and just pull the linkage down , the pan will come right out . I took mine down 3 days ago .
geo
geo
A CI-6 Car Show Winner
I think you could undo the bolts holding the idler to the right side of the frame and drop the whole linkage far enough to remove the oil pan.
Thanks guys, you are all great. This is the best place ever. I'll be out in the shed this weekend, thanks again for the quick response. :hurray:
