Rear Crossmember bushing?
Cruise-In VII Veteran
St. Jude Donor '07
I've seen these made out of alum. Where can I get them? Mine look like they have a 1/8" gap between the frame and crossmember.
Re: Rear Crossmember bushing? (Budman78)
See page 25 of VBP's on-line catalog. Closest thing I can think of for what you're describing. "Differential Cross Member Re-Enforcement Kit" I have them on mine and have had zero problems.
http://www.vettebrakes.com/
Good luck.
Good luck.
Re: Rear Crossmember bushing? (Schmucker)
But is there anything special about them? Looks like one could just make them youself.
There is supposed to be a gap between the frame and crossmember. That's how the sombrero mounts are designed. What is the problem you're trying to correct?
St. Jude Donor '07
Re: Rear Crossmember bushing? (sb69coupe)
No problem now. Two people have now told me there is suppose to be a gap. I'm going with that. The gap stays. Thanks for the heads up. :cheers:
