Can anyone help to identify this part..? I found this when I opened up the motor
Old 02-11-2003, 03:08 PM
HDIronman
HDIronman's Avatar
Default Can anyone help to identify this part..? I found this when I opened up the motor
Just thought I'd share with you all. Fortunately the motor is running again, three cylinder sleeves later. Plus, some other go fast parts went into the rebuild. Any other horror stories that anyone would like to share with the rest of us...????
What's the worst that has happened to your engine?
[Modified by HDIronman, 3:10 PM 2/11/2003]
Old 02-11-2003, 04:31 PM
Paul Borowski
Support Corvetteforum!
Paul Borowski's Avatar
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Default Re: Can anyone help to identify this part..? I found this when I opened up the motor (HDIronman)
From the shuttle Columbia??? :confused:
Old 02-11-2003, 04:51 PM
Metal Wulf
Metal Wulf's Avatar
Default Re: Can anyone help to identify this part..? I found this when I opened up the motor (Paul Borowski)
:eek: holy crap!!
Old 02-11-2003, 04:56 PM
Smokehouse69
Smokehouse69's Avatar
Cruise-In VII Veteran
Are you sure that isn't a Ford piston, it looks a lot like one I saw that came out of 5.0 'rustang after a 300 shot of NOS! :rofl:
Wow! that is one seriously messed up piston and rod! About the only thing that could be worse would be for you to tell us that it's a cam shaft! :D
Old 02-11-2003, 04:59 PM
Brettmc
Brettmc's Avatar
Someone put marbles in your gas tank?????
Old 02-11-2003, 05:05 PM
Eddie 70
Eddie 70's Avatar
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Can anyone help to identify this part..? I found this when I opened up the motor (Brettmc)
Dayumage. Running the poo out of it, no doubt. This is always one of my fears after having spent so long with no motor in the car. I am just taking it easy on it right now. :D
Old 02-11-2003, 05:13 PM
My69
My69's Avatar
Unbelievable!!! :smash:
Old 02-11-2003, 06:35 PM
Maurice
Maurice's Avatar
You should be proud you got your moneys worth out of that piston!!
Old 02-11-2003, 07:42 PM
Dwayne 76
Dwayne 76's Avatar
What would cause that?
Old 02-11-2003, 07:44 PM
PatsLs1vette
PatsLs1vette's Avatar
Default Re: Can anyone help to identify this part..? I found this when I opened up the motor (Dwayne 76)
oh ive seen a few of those in my circle track days :yesnod:
Old 02-11-2003, 08:02 PM
norvalwilhelm
norvalwilhelm's Avatar
I have a few blown pistons but nothing as good as that. What destroyed the piston and rod that badly?
Old 02-11-2003, 08:09 PM
'79ProwlerOrange
'79ProwlerOrange's Avatar
Default Re: Can anyone help to identify this part..? I found this when I opened up the motor (norvalwilhelm)
:eek: :eek: :eek: :eek: :eek: Dayum!
Old 02-11-2003, 08:24 PM
0Mike69@ECS
Former Vendor
Mike69@ECS's Avatar
Cruise-In III Veteran
Cruise-In V Veteran
:eek: :eek: :eek: Whoah!!!!!!!!! What the hell was in the cylinder??? Your tool box???? That has to be painful!!!!!!! :eek:
Old 02-11-2003, 08:32 PM
NHvette
NHvette's Avatar
I have NEVER seen a flux capacitor so badly damaged by static discharge.
You're gonna need a new one, me thinks.
BTW - what kind of sound does it make when a piston lets go like that ?
No - never mind - I don't ever want to know.
:seeya
Old 02-12-2003, 10:07 AM
HDIronman
HDIronman's Avatar
Happened while driving 70mph on the e-way. No big bang, just a little noise and so much smoke I couldn't see to pull over to the side of the road.
Can't say exactly what caused the damage, but I beleive it was a valve that hit the piston. Also found a short piece of the valve stem embedded in the head, like it was shot from a gun. Number 5 cylinder wall was completely gone. Fortunately the bottom end was okay. Everything is back together now and I'm dying to get back on the road in spring.
:auto: :auto: :auto: :auto: :auto: :auto: :auto:
Old 02-12-2003, 10:46 AM
GDaina
GDaina's Avatar
Sounds like a valve spring broke and dropped the vale into the cylinder.
Old 02-12-2003, 10:50 AM
Dwayne 76
Dwayne 76's Avatar
Default Re: Can anyone help to identify this part..? I found this when I opened up the motor (GDaina)
May I NEVER have to expierence that :chevy
To Can anyone help to identify this part..? I found this when I opened up the motor
Old 02-12-2003, 10:55 AM
Fevre
Fevre's Avatar
Thought pistons/rods where part of the 'bottom end'? :confused: I would think with that much damage your crank might be bent if it is cast. I had a piston completely shatter leaving just the rod and pin in the cylinder with two long narrow holes in the sleeve where the pin dug into it.
Old 02-12-2003, 10:57 AM
Cajun99
Cajun99's Avatar
WHOA!! :eek: :eek: :eek: :eek:
Nothing so far. :cool:
~37K original miles, never been opened up and still running fine. In fact the weather's great and I'm fixing to take her for a cruise!! :yesnod:
Good luck with your repairs...man that sux!! :cry
Old 02-12-2003, 12:23 PM
redvetracr
redvetracr's Avatar
Three sleeves is enough of a horror story for me, YOU are a braver man than I !! ...redvetracr
Quick Reply: Can anyone help to identify this part..? I found this when I opened up the motor
