Can't just ONE thing go smoothly?!
Old 02-11-2003, 01:47 PM
sb69coupe
sb69coupe's Avatar
Default Can't just ONE thing go smoothly?!
I'm in the middle of a front suspension rebuild, and everything I've touched has taken 3X as long as it should. Case in point, today. I'm trying to burn out the old rubber bushings. The first one takes forever, I'd burn a little, dig it out with a screwdriver, and burn some more. The second one actually caught fire and came out easily. The lower ones were much more difficult. I spent an hour on one lower arm, then threw in the towel. Decided to move on to the tie rod ends.
Of the 4 tie rod ends, none of them would budge in the sleeves. I clamped the tie rod sleeve in the vice and fought like crazy to no avail. Second towel thrown in. I called a friend who has a local shop and asked if he could finish what I started. I took the parts down to him, and carried the transmission with me so he could check it out too.
On the way how, the tranny rolls onto its side and deposits a quart of gear lube into the rear storage liner in my car.
It's times like these when I question my own sanity. :cry
Old 02-11-2003, 01:52 PM
ZD75blue
ZD75blue's Avatar
Default Re: Can't just ONE thing go smoothly?! (sb69coupe)
Ouch!
Just another one of those days... better hop in bed! I have those every few weeks my self, so dont feel alone :cheers:
Old 02-11-2003, 02:15 PM
Makonut
Makonut's Avatar
Well anybody could own a new problem free car. It`s a vette. ;)
Old 02-11-2003, 02:58 PM
HDIronman
HDIronman's Avatar
Everything you stated sounds perfectly normal to me...!!!
I use this rule of thumb....."if it should take one hour to complete a task, I can safely triple that time."
:banghead: :cool: :thumbs:
Old 02-11-2003, 03:33 PM
BB wowbagger
BB wowbagger's Avatar
Default Re: Can't just ONE thing go smoothly?! (HDIronman)
:withstupid: :withstupid:
Thats an exellent rule..I`m using it on everything i do... :cheers: :cheers:
Old 02-11-2003, 04:21 PM
Stewart's74
Stewart's74's Avatar
Try using a hole saw to remove the A-Arm bushings. A number of Forum members have used this method.
Old 02-11-2003, 04:37 PM
Eddie 70
Support Corvetteforum!
Eddie 70's Avatar
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Can't just ONE thing go smoothly?! (Stewart's74)
[tommyboy]SON-OF-A.......Thats gonna leave a mark[/tommyboy]
Old 02-11-2003, 04:41 PM
Alwyn678
Alwyn678's Avatar
Default Re: Can't just ONE thing go smoothly?! (Eddie 70)
Got my car running good and now the driver's door will not budge.........DAMNIT :cry :cry :cry :cry Always something :cry
Old 02-11-2003, 04:44 PM
scottw
scottw's Avatar
To answer your question, I'd say NO.
I always start a project with no problems and end up just as fustered as you.....Arn't vettes fun!
Old 02-11-2003, 04:56 PM
Guest
Guest
Posts: n/a
Dayum, Shannon, sorry to hear about those issues. I was wondering about the tierod ends the other day when we were looking and talking about them. They looked like they were quit comfortable and didn't want to go anywhere. :smash:
Gee, the things I have to look forward to.
Good luck bro.
Rob
Old 02-11-2003, 06:19 PM
Paul Borowski
Paul Borowski's Avatar
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Default Re: Can't just ONE thing go smoothly?! (RLH)
That spilled gear lube too will usually smell a good while-that stuff stinks :yesnod: :party:
Old 02-11-2003, 11:29 PM
ry
ry's Avatar
Default Re: Can't just ONE thing go smoothly?! (BB wowbagger)
Old 02-12-2003, 12:26 AM
tersian
tersian's Avatar
Default Re: Can't just ONE thing go smoothly?! (ry)
I know how you feel. I'm no electrician but tonight I went out to complete the rewiring of an old 3 switch box that was populated with dried up and freyed romex and 4-way switches where 3-ways are needed etc. etc. I earmarked an hour for the job, only to discover that when BUBBA wired it, he decided not to use any standard color for anything and wired the common line white to black in a splice half way through the circuit so I had no idea until I was forced to check continuity on every line and shock myself half sane! :banghead:
Old 02-12-2003, 12:30 AM
mapman
mapman's Avatar
I get the same feeling - years of neglect and abuse are difficult to overcome. I feel like I am going to have to touch every system - every part.
I guess the good news is, with a finite number of parts the task will end someday.
Try this, make a list (long list) of everything that remains to be done on the car. I did this and at first I was discouraged - but later I realized that there really is an end! I am checking the list off as I complete each task. (In honesty, I've had to add a few new items now and then :cry )
Old 02-12-2003, 12:31 AM
Guru_4_hire
Guru_4_hire's Avatar
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Can't just ONE thing go smoothly?! (tersian)
I am about a year into an engine rebuild
To Can't just ONE thing go smoothly?!
Quick Reply: Can't just ONE thing go smoothly?!
