74 Roadster..Check out the grille on this 74..Car is pretty bad azz
Re: 74 Roadster..Check out the grille on this 74..Car is pretty bad azz (Alwyn678)
I like the grille, but thank god disco is dead. :lolg:
Re: 74 Roadster..Check out the grille on this 74..Car is pretty bad azz (Stewart's74)
painter took a touch too much Acid in his youth
I would actually like to do something like this on the front of my '71 and eliminate the parking lamps. Has anyone seen a billet aluminum grill aftermarket for these cars?
Re: 74 Roadster..Check out the grille on this 74..Car is pretty bad azz (groovyjay)
:lolg:
:lolg:
:lol: all you want friends and neighbors. But that car is a terrific example of The Way it Was Done. Twenty years from now cars done up '70s style are only going to exist in picture books. I'd much rather look at a bunch of these than the typical 1980s-1990s style monochrome-and-gray-tweed "Me Toomobiles."
That grille looks pretty cool. Wish I could see more pics of the thing. It looks as though the slight curvature has been taken out of the nose of the Vette and the grille is made of straight bars.
When I first started making my grille, I assumed the nose of my car was straight on each side of the point . . . not so. That was the hardest part of fabrication. I built each of the bars with a slight curvature that matched the nose. It's subtle detail but one that made the grille look like it came from GM or a quality aftermarket piece.
Thanks for sharing . . . been to busy searching for a car to keep up with the forum. :lol:
Re: 74 Roadster..Check out the grille on this 74..Car is pretty bad azz (74-Roadster)
