Gonna go a little crazy w/ exhaust wrap, also rear spring...
I just picked up everything I need, except the exhaust wrap and marine grease, to install the rear spring.
I'm thinking of maybe wrapping the pipes that go underneath the footwells. Think this well help with cabin heat?
Also, I'm going to wrap the pipes that cross under the rear spring. Should I wrap the spring itself as well? Was thinking of the Thermo-Tec exhaust wrap. http://store.summitracing.com/partdetail.asp?part=2359
-Steve
-Steve
Re: Gonna go a little crazy w/ exhaust wrap, also rear spring... (Pacin'California)
Dunno if that's a good idea. the wrap can trap moisture and the pipes rust out. Of curse that's a good reason to get a stainless system...
Re: Gonna go a little crazy w/ exhaust wrap, also rear spring... (zwede)
Good point. Sounds like it might be better to just try something around the rear spring and eventually upgrade the heat insulation in the footwell. Any tips?
Thanks very much. :)
-Steve
-Steve
Re: Gonna go a little crazy w/ exhaust wrap, also rear spring... (Ed T)
Ed- Those are some great pictures. Your first one on the other post inspired me. How close do you think your pipe is there? It looks pretty close. Mine are about that close, I think, and I worry about heat.
Which part store do you usually frequent? Kragen had nothing of interest for me today. What should I ask for? The stuff you put on looks almost like insulation. (To my untrained eye, anyways...)
-Steve
-Steve
My ACe mechanic does not recommend using Thermo Tec wrap for vehicles used daily. In his opinion, it is for weekend racing use only.
It is a very effective product and retains heat so well that it causes thermal fatigue and failure of the the wrapped component such as headers. The higher the internal heat, the faster the failure. Althought this looks like rust, as per Markus' comment, it is really thermal fatigue.
If you want to wrap something, wrap the spring itself.
I have had a TRW rear spring installed for several years with only the metal heat shield and haven't had a problem.......
Re: Gonna go a little crazy w/ exhaust wrap, also rear spring... (flynhi)
Ed- One of these days, I'm going to have to come over to have dinner on your halfshafts. :)
Thanks for the help, everyone. The search for thermo-tec begins today. I am really unsure of how much exhaust clearance I have... Guess I'll have to get the measuring tape out when I'm under there.
I should have it done today, unless I decide the exhaust clearance is too little.
-Steve
-Steve
Moderator
I wrapped mine and the pipes are fine after two years, not a daily driver though. Don't think the trapped water idea holds up IMO, the heat would dry the wrap in a few seconds and since mine is stored inside, no moisture gets on it. After I wrapped mine I drove it to a gas station to fill up. When I shut it off it started to smoke, and I mean BIG TIME smoke. Thought the whole darn thing was on fire! :eek: Turned out the thermal wrap was 'burning in' and all was well. Took a few days to quit smoking/stinking so be aware of this and do not worry.
