Spicer U-joint p/n
Spicer U-joint p/n
Can someone give me the part numbers for the Spicer U-joints for a 69 300hp? I would like them without the grease fitting.
Thanks
Thanks
Re: Spicer U-joint p/n (69side)
Thanks
Thanks
I'm not sure about the driveshaft ones...
:cheers:
Olivier
Re: Spicer U-joint p/n (GrandSportC3)
I think that the driveshaft p/n was 5-625x.. However - the Spicer p/n recently changed.. so the p/n might be different now...
I just changed all of my u-joints. Mine used 1310 series on the driveshaft and 1350 series on the half shafts. The Spicer numbers listed on their website http://www.spicerdriveshaft.com are SPL22-1X (driveshaft) and SPL30-1X (half shaft), but I was told 5-799X is the catalog number for the half shaft. That was also the number on the box. Go figure :confused:
But not all vettes use 1310 series on the driveshaft. At some point they changed to the slightly larger 1330 series (Spicer part no. SPL25-1X), but I am not sure which year or what transmission type.
