Where is the ground wire to the frame for interior lights and dash panel?
My car has what I believe to be a non original wire shunt across the rag joint. The other day I broke the shunt and had no interior lights. I replaced the shunt and everything is fine again, but where is the original ground wire to the frame for the instruments and interior lights. If it makes any difference, I have a 77.
Re: Where is the ground wire to the frame for interior lights and dash panel? (virtue4u)
I's assume yours is the same, but on my '82 the dash harness ground is located behind the upper left corner of the dash, behind the speedo/tach housing, near the windshield pillar and windshield wiper arm mounts.
My 81 also has the ground attached behind the dash on the inner firewall under the window.
