Anyone switch to 17inch wheels?
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Re: Anyone switch to 17inch wheels? (electricblue)
Many of us have. I went to the 1996 Corvette wheels, and used adapters from Vette Brakes.
The change in handling is incredible, I turn the car and it IMMEDIATLY turns. It doesn't have the Cadillac smooth ride that it did before but when I put it into a corner it stays put. No wiggle, slide or hop - just GO!
If you stay with the stock 8" width with 4" backspacing, you shouldn't run into too many problems. If you find a wheel that you like, post here to see if others have used them with any problems. Some wheels have trouble clearing the brake calipers on the C3's so spacers or adaptors may be required. Stepping up to a larger diameter wheel does improve the handling of our old cars though ;) .
Re: Anyone switch to 17inch wheels? (Jason Staley)
I just recently put some 17s on my car. Boyd Coddington Timeless 5 wheels.
After seeing the awesome 69 Mr.Tarbox has and how great the Boyds looked i have just ordered the Boyds timeless 5 also but 17 x 8 all the way around and 245/45-17 Yokes on the front and 245/40-17 on the rear Ill let you know on how well the work out also just finished with KYBs all the way around
:party:
:party:
Re: Anyone switch to 17inch wheels? (Zack Wenning)
17x8.5 VortecZ from Performance Wheel Outlet. It highly resembles a C5 Y2K five spoke wheel. Get a hold of any Vette-type mag and look for their add. I can email pics.
Re: Anyone switch to 17inch wheels? (lobwedge)
:party:
:party:
But... make sure you get the right sized tires. From what you posted above your front tires will be taller than the rear ones. ????
Re: Anyone switch to 17inch wheels? (WA 2 FST)
There are no ultra high performance tires in 15 inch anymore. I'm even starting to think that 16&17's are about gone also in the diameters you really need.
But other than that. If your going to spend the money figure out the tires size you need first and then what wheel you need.
