Something that might look good under our hoods
http://www.thirdgen.org/techbb2/atta...postid=1126384
Twin eaton supercharged TPI, and it might even fit under the stock hood and work with the cowl hood of mine. :cheers:
[Modified by Fevre, 1:59 PM 2/7/2003]
Re: Something that might look good under our hoods (Fevre)
:skep:
Re: Something that might look good under our hoods (OHSIXX)
:skep:
Here is how it looked before I made it a link :
[Modified by Fevre, 2:01 PM 2/7/2003]
Much better! :cool:
Only problem is my I don't think my t-5 would like the extra umph. That is assuming I get the thing to work. :)
Re: Something that might look good under our hoods (6t9l4t6)
Here is a link to the site that it is posted on.
http://www.thirdgen.org/techbb2/show...hreadid=158641
Not sure if he did for max performance or just to prove it could be done. Wonder if it gives more low end then a supercharger?:confused: Guess I cousl ask. :)
I wouldn't go for it. Double the maintenace, very hard to set valves, hard to get at the plugs, the mounting for the superchargers would have to be vary rigid or the superchargers would throw belts.
Give me one larger supercharger right in the middle :)
Re: Something that might look good under our hoods (norvalwilhelm)
Re: Something that might look good under our hoods (BB wowbagger)
BB wowbagger. I would prefer a 10-71 over my 8-71 but I got a deal on the 8-71 $4000CDN, the 10-71 would still fit without distributor interference but I am not sure about the 14-71. Each step up in the blower size adds 1 inch to the length. My distributor clears fine with this setup.
I have no problem running 12 psi boost but it is overdriven by 15%. With a larger supercharger I would still run the same 12 psi but could slow the blower down to keep the mixture cooler.
Ooops..I forgot a :iagree: smiley..
No pun intended.I really like your S/C setup..
:cheers: :cheers:
:cheers: :cheers:
