MOTOWN 220 Heads
Old 02-06-2003, 08:22 PM
nastee383
nastee383's Avatar
Default MOTOWN 220 Heads
Has anyone seen any info on the flow characteristics of World Products MOTOWN 220 Heads? If so, where can it be found?
Old 02-07-2003, 02:31 PM
Arto
Arto's Avatar
Default Re: MOTOWN 220 Heads (nastee383)
Only official specs I know of are in the World catalog:
http://www.worldcastings.com/docs/catalog/pg14.pdf
However, you should be able to find some numbers & graphs in this article:
http://www.circletrack.com/techarticles/88478/
And no numbers, but Chevy High Performance compares Motown 220 aluminium vs. iron:
http://www.chevyhiperformance.com/techarticles/83858/
Regards,
Arto
Old 02-07-2003, 04:17 PM
Fevre
Fevre's Avatar
Here is a article on an eng build using them. Pumping out 528 hp on a 350 ainpt too shabby.
http://www.hotrod.com/techarticles/113_0302_anvil/
Old 02-07-2003, 04:33 PM
QuickVet
QuickVet's Avatar
Default Re: MOTOWN 220 Heads (Fevre)
I think Bill Mitchell uses them on his 427 small blocks. Im sure they can handle any job up to 750HP :yesnod:
Old 02-07-2003, 04:37 PM
GrandSportC3
GrandSportC3's Avatar
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Re: MOTOWN 220 Heads (QuickVet)
:iagree:
Old 02-08-2003, 01:54 AM
8T1-7T9 BIONIC VETTE
8T1-7T9 BIONIC VETTE's Avatar
They also come with the Bill Mitchell 415c......they were on mine.....Killer heads....I have a set of AFR 210 I was hoping to put on the 415ci....however the Motown 220's are working so well.....I don't want to f'k-it-up...... :seeya Cappy
Old 02-09-2003, 04:39 PM
nastee383
nastee383's Avatar
Default Re: MOTOWN 220 Heads (FlyingFinn)
Regards,
Arto
Thanks, that CIRCLE TRACK article was informative. I would've never looked there.
Old 10-17-2012, 01:46 AM
buccaneer1961
buccaneer1961's Avatar
Default motown vs afr
Originally Posted by 8T1-7T9 BIONIC VETTE
They also come with the Bill Mitchell 415c......they were on mine.....Killer heads....I have a set of AFR 210 I was hoping to put on the 415ci....however the Motown 220's are working so well.....I don't want to f'k-it-up...... Cappy
i guarantee you those afr 210s will make 50 hp more than those motown 220s i had both
To MOTOWN 220 Heads
Quick Reply: MOTOWN 220 Heads
