DynoMax Headers On a 72 SB - Did You Have To Relocate Plug Wires?
:confused:
Cruise-In IX Veteran
Re: DynoMax Headers On a 72 SB - Did You Have To Relocate Plug Wires? (OHSIXX)
You cannot route the wires like they were with manifolds. I just pulled them out of the way on 71 and zip tied the wires away from the header tubes. It was fairly easy to do. When I changed motors I got a special set of wires to run on top of the valve covers so I did not have long wires hanging all over the place.
Mark B.
Mark B.
Re: DynoMax Headers On a 72 SB - Did You Have To Relocate Plug Wires? (Sigforty)
Get a wire loom(get them at pepboys) chrome and use that to run the wires also you need to get angled boots...instead of straight
[IMG][/IMG]
[IMG][/IMG]
I used Taylor wires with some of them having custom boot angels(some 45deg. and some 90s). then I took several Taylor wire ties (some 2 , some 3, some 4) and routed them neatly and pulled from the headers. They have never hit the headers since.
Re: DynoMax Headers On a 72 SB - Did You Have To Relocate Plug Wires? (Clink69)
The stock wire routing was a dumb idea to begin with. Get new wires and run them thru some wire looms. Makes working on the engine much easier.
I installed a set of Accel 8.8 mm plug wires (w/ 90 deg boots) on my '73 small block with Dynomax ceramic-coated headers. The wires follow the stock routing with all the shielding and covers in place.
I wasn't easy, had to jack the car and remove the starter, but the end result was worth it. And judgin by the past owner, I won't have to replace those wires for another 30 years!!!
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Re: DynoMax Headers On a 72 SB - Did You Have To Relocate Plug Wires? (SlixVett)
When I get home I will snap some pictures of my plug routing with my Hedman headers on my ZZ4 motor.
I used Accel wires and the stock routing. I haven't had a problem yet. I did remove the rear spark plug shields but other than that it's stock including the rest of the shielding. You can see the front wires in my sig.
Re: DynoMax Headers On a 72 SB - Did You Have To Relocate Plug Wires? (vettfixr)
I ordered the wires and loom kit from Jegs today. Maybe I will have everything together next week, I hope.
Re: DynoMax Headers On a 72 SB - Did You Have To Relocate Plug Wires? (Stewart's74)
