Ever consider one of these
Cruise-In IV Veteran
Cruise-In V Veteran
Re: Ever consider one of these (Denmech)
Edelbrock C-26 dual quad manifold for the smallblock and a pair of performer carbs
Re: Ever consider one of these (Guru_4_hire)
I have never used a setup like this but I would love to hear some opinions on how they work on a BB. I think that would look cool under the hood. :cheers:
Re: Ever consider one of these (BlackRat)
Dual fours are cool, I've always wanted a set. Better yet a Cross ram
All I can say is groooooovy.
HOT ROD did a test on them, they were down about 30 hp on a really built 350,,,as compared to a single race-prepped Holley on a Victor Jr.,,but the cam didn't match the carbs either,,,they can be tuned, and adjusted to give good performance on torque built engines,,,that is a dual plane manifold so you would have to build it around a 5500 RPM motor,,,and yes they are really :cool: looking!
I seriously concidered this combination,and after pricing out the carbs,linkage and fuel line connection,found that for very few extra bucks I could stroke the 350 to a 383. For the money spent,the bang for the buck would be the stroker kit. When I went to the machine shop to get his price for a stoker,I ended up going to the 406.This is still a cool intake setup,but looks wasn't what I was after. :D
The manifold is always for sale on E-bay used & the Edelbrock 500 CFM's also,,could build this fairly cheap from E-Bay!
Cruise-In V Veteran
Re: Ever consider one of these (Smitty's75)
They make a big block version. What I really want is an weber downdraft set up like old race engines but that is mega bucks
You like the old Webers? How about this for a juxiposition of old and new- an eight ported fuel injection system set up to emulate the Weber look but with modern performance.
Greg P is building a pro-street 65 coupe. Here's a picture of his engine.
Cruise-In V Veteran
Re: Ever consider one of these (Mac)
http://www.inglese.com/
Pretty neat if you have a 2-5K to blow -- can even get them gold plated
When I build a kit cobra I am gonna use their products to build a 302 with a weber intake like the cobra 289
[Modified by Guru_4_hire, 3:03 PM 2/6/2003]
My dad's '64 runs two Holley 600cfm carbs on a tunnel ram. Of course his engine can make use of all that as it makes all of it's power up high. Dual carbs aren't really necessary besides for looks on a street motor. The main reason is, where are you going to find a 1200cfm carb that can feed as much fuel as two 600cfm ones? How built does your motor have to be to need that much fuel?
