79 headlamps stuck open
Re: 79 headlamps stuck open (DKBLUE79)
From the underside...push back on the joint at the end of the actuator shaft. Once you start the movement, they should continue to fall by themselves. Maybe someone can put this into words better than I can. Also, never push down on the headlight doors from the top.
