Check out this 81 Vert on Ebay...
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6168
Seems like a interesting car.. Looks like a good deal if they can document the 49000 miles...
:cheers:
Olivier
:cheers:
Olivier
Re: Check out this 81 Vert on Ebay... (n8370c)
I agree. those old odometers hide the 6th digit nicely.
It's hard to tell for sure, but the steering wheel and seat indicate a BIT more than 49k.
It still looks like a decent deal at 10k - if the frame/BC are solid.
Try any find ANY decent vert (not just vette) for much less than that.
:seeya
[Modified by NHvette, 2:59 PM 2/4/2003]
:seeya
CI 7-8 Veteran
Re: Check out this 81 Vert on Ebay... (HrdAtWrk)
Didnt they stop making convertables in 1975 ???
IF that is the case it is someones custom job.
And that engine bay...OUCH....perfect AR candidate, right Olivier?! :thumbs:
:cheers:
Olivier
Re: Check out this 81 Vert on Ebay... (tshort)
That's what I was thinking. There are other things that seem a little odd/off about that car. For example, why no pics with the top down? Also, the right rear wheel seems to be cambered a little weird....I didn't realize you could adjust them so maybe there's a problem. It may also just be a funky camera angle producing an illusion.
:cheers:
Olivier
Re: Check out this 81 Vert on Ebay... (NHvette)
:seeya
:seeya
If its truely 49000 miles then it sat outside with the top down and hood up for a long time. Also note that carfax cannot document original mileage - all it can do is indicate if it suffers from odometer rollback. Since carfax only returns mileage at sale of the car.......
For example if this car was purchased by its current owner 10 years ago with 30k miles on it - he could drive it to any mileage he wanted - and provided it stayed with that owner - he could then roll the odemeter back to any number above that 30k and it would still come up ok on carfax.
3k max from me
Re: Check out this 81 Vert on Ebay... (GrandSportC3)
is it me or is that emblem crooked? :skep:
how sad, that pretty much how my engine looks. and it has 3000 miles on it. of course i can power wash most of my grit and grease off.
Re: Check out this 81 Vert on Ebay... (fauxrs)
I don't think that you can "Carfax" 1981 cars at all...
:cheers:
Olivier
:cheers:
Olivier
Paint looks very rough, fit and finish are poor. I'd say that whomever did the convertible conversion 'cut corners'... Now, if it was in the same condition as your Duntov BEFORE the accident, I'd say $10k no problem... :cheers:
Re: Check out this 81 Vert on Ebay... (TedH)
:cheers:
Olivier
Re: Check out this 81 Vert on Ebay... (PB82CE)
WOW!!!!!! Someone already fixed up Oliver's '81 Duntov, made it look like a stock '81 :cool: , and put it on eBay. WOW, that was quick :steering:
CFOT Attention Whore
run, run away fast! aint no way.
just from a real quick look, this is what i see:
non-stock rear bumper
'82 horn button
non-functional computer control (if it's even there)
wrong carb
wrong distributor
no spare tire tub
wrong wheel centercaps
(just a sidenote, wrong tires for the aluminum wheels)
besides that, yeah the emblem is screwy and the paint isn't great and the interior is rough, and what the hell is going on with the rear wheel/body alignment?
:nono:
[Modified by clutchdust, 4:38 PM 2/4/2003]
'82 horn button
wrong carb
wrong distributor
no spare tire tub
:nono:
