ring gear i.d
Old 02-04-2003, 02:35 PM
vettedreams
vettedreams's Avatar
Default ring gear i.d
Had to pull the rear end down due to thrashing :smash: and was wondering if someone could decifer this code stamped on the ring gear. 3733908 GM 10 37 2 76 1. thanks again.
P.S. the more I work under the car the easier it get"s to tear her down :D :D
Old 02-04-2003, 02:41 PM
norvalwilhelm
norvalwilhelm's Avatar
Default Re: ring gear i.d (vettedreams)
If you are trying to figure out the ratio just could the number of teeth on the ring gear and the number of teeth on the pinion then divide the lower number into the bigger number and it will tell you the ratio.
Old 02-04-2003, 03:07 PM
vettedreams
Default Re: ring gear i.d (norvalwilhelm)
THANKS
Old 02-04-2003, 05:29 PM
Gordonm
Gordonm's Avatar
According to my book a ring gear with 37333908 is from a rear with 4.11 gears. The pinion should be stamped 3885945. The pinion should have 9 teeth and the ring gear should have 37 teeth. Kind of rare as the 4 series carrier is not very plentiful. The other numbers are date codes
Old 02-04-2003, 05:33 PM
Chuck Gongloff
Support Corvetteforum!
Chuck Gongloff's Avatar
Default Re: ring gear i.d (Gordonm)
The "10 37" tells me it's a 3.70 set. 37 teeth on the ring gear, and 10 on the pinion. The other is the date "month---year", Feb. 76. Chuck
[Modified by Chuck Gongloff, 5:34 PM 2/4/2003]
Old 02-04-2003, 07:06 PM
Gordonm
Gordonm's Avatar
Default Re: ring gear i.d (Chuck Gongloff)
That is what I thought my book must not have correct numbers,
Old 02-05-2003, 12:18 AM
vettedreams
Numbers are great, ain"t they :jester thanks again for the info.
Old 02-05-2003, 12:27 AM
vettedreams
I had to go out there and check one more time, and sure enough the pinion is 9 splined, if I can say that! Bubba musta been there back when :lol: :lol:
To ring gear i.d
Quick Reply: ring gear i.d
