What are the specification differences between the L-46 and L-T1?
And please don't answer "20 horsepower".
I think the LT-1 had a solid lifter cam but that's about all I know about it. I'm more interested in the L-46 side of things
Re: What are the specification differences between the L-46 and L-T1? (Neo Fender)
Some LT1 fans will kill me but the L46 is "basicly" a hydraulic lifter version of the LT1. :) The LT1 used a Holley while the L46 was Q-jet. LT1 had solid lifter cam, L46 was hydraulic. Both had the big valve heads. Both had 4-bolt mains. Not sure on the compression but believe they were close to the same.
tom...
[Modified by Tom73, 4:33 PM 2/4/2003]
tom...
Re: What are the specification differences between the L-46 and L-T1? (Tom73)
high rise aluminum intake
Solid lifters and cam
more duration on cam than L46
6500 redline
no fuel return line
holley 780 cfm vac sec carb
void of options (except a few rare versions)
compression on both should be 11:1
actual HP closer to 400+ than 370
There's a start on the LT-1.
Peak HP at 6000 RPM
Peak torque (380) at 4000 rpm
[Modified by Robert N, 12:06 PM 2/4/2003]
6500 redline
no fuel return line
Peak HP at 6000 RPM
Re: What are the specification differences between the L-46 and L-T1? (Robert N)
Robert N is right on. Both are great motors, you could take a L-46 and easily make it a LT-1 with air in 69 or 70 if you wanted. :D
