Dextron 2 or 3 in TH350
Hi all
Somebody tell me that is no good to put Dextron 3 in an TH350, What do you think about this ? If is true, why is no good and what are the risk ? Thanks in advance for yours responses. :seeya
Re: Dextron 2 or 3 in TH350 (French78)
Dexron III is the only Dexron fluid available at the auto parts stores. Dexron III is safe for all Transmissions requiring Dexron x transmission fluids including Powerglide, TH350, TH400, 700R4, etc.
Cruise-In VI Veteran
Cruise-In VII Veteran
:iagree:
I read that you can improve the firmness of shifts on a TH350 or TH400 by using Ford (Type F) ATF. It is supposed to be a little less slippery than Dextron. I believe that B&M Trickshift ATF which is "For all Automatic Transmissions" is nothing but Synthetic Type F.
I tried Type F in my TH400 and it has worked faultlessly and gives much firmer shifts, without installing a shift kit.
[Modified by Smokehouse69, 4:14 PM 2/3/2003]
I used Dextron III in my 80 Duntov...
:cheers:
Olivier
:cheers:
Olivier
Re: Dextron 2 or 3 in TH350 (Smokehouse69)
Ummm...if I was in Texas where I know I can get a replacement tranny for under $200, I'd try Type F. If I was in France where a TH350 is $$$, no way. Use Dexron III. It will be fine. I don't think you can even buy Dexron II any more.
[Modified by page62, 4:59 PM 2/3/2003]
