Clutch replacement questions-I am going with a Centerforce DF
When my motor is out of the car for the rebuild, I am going to go ahead and replace the clutch with a Centerforce DF.
I know I need to replace the clutch, pressure plate, and throwout bearing, but should I go ahead and replace the fork and pivot ball or is that a "wait and see the condition" kinda thing?
I know I need to wait and see if I have the 10 spline or 26 spline (I am assuming the 10, but I want to make sure), but should I get the 10.5 inch or 11 inch? Is it like most anything else, bigger is better?
Finally, who has the best price on these things?
Thanks!
Thanks!
Re: Clutch replacement questions-I am going with a Centerforce DF (hudman)
No need to replace the fork if it's still in ok condition, Are you using stock bellhousing or Lakewood etc.? Adjustable pivot ball is a must with lakewood bellhousing. As for the clutch go for the 11". :cheers:
The DF is a great clutch. I had one on an '80 350 that I put in a Jeep Scrambler. Drove the thing for about 10 years and the clutch still felt like the day I got it when I sold the Jeep. Ran 33" tires and a 3.56 rear, and never had a slippage - even when I got "aggressive"....
Go for the 11" and as said previously, replace the fork if it has excessive wear.
Good luck.
Good luck.
