? on cleaning and coating exhaust manifolds
I know there is a dress up product that makes the manifold look new again. But I can`t remember the name. Also does it work and how long does it last?
Re: ? on cleaning and coating exhaust manifolds (Makonut)
The Eastwood Company has very good products which address manifolds. If you want somethig permanent, you might want to consider ceramicoating. There are a couple different finishes and one bennefit is its a thermal barrier which helps with the under hood temperature problem corvettes are famous for.
:yesnod:
:yesnod:
Re: ? on cleaning and coating exhaust manifolds (max125)
You probably mean Calix.
I like the Cerma chrome stuff by techlinecoatings, you have to have a pretty hefty oven for that stuff though.
I've heard good things about "Cast Blast." I think I'm going to try it on my master cylinder (I have ceramic coated headers).
Re: ? on cleaning and coating exhaust manifolds (rainman69)
