Ride Height
Ride Height
Need some of you (the more the merrier) to measure your front and rear ride height. I talking about putting a tape measure from the ground straight up to the top of the fender opening arch with the tape splitting right through the center line of the wheel hub.
I'm thinking you should be in the 27-28" range, with the rear an inch higher than the front.
:cheers: :smash: :cheers: :smash: :cheers:
