Looks like I'm not selling the 82 afterall
Old 01-31-2003, 07:41 PM
Wrecked82
Wrecked82's Avatar
Default Looks like I'm not selling the 82 afterall
After long discussions with my friend about buying my car, he actualy convinced me that I would regret it - which I was beginning to feel even before we struck a deal.
He has owned a 1963 Split Window Fuelie Coupe, a 1971 big-block Roadster, a 1977 Coupe, and a 1987 Roadster very modified. Also owns now, and in storage, a Super Bee and a Plymouth Road Runner.
He actually was willing to go over $20K for my 82. This is what has been done to it starting with the front:
Rubber air dam
Both headlight actuators - headlights are all new
Radiator
Water Pump
Stainless steel chrome top radiator hose
Chrome water neck.
Water pump - in last 4 months
Washer pump
Engine - LM1 - rated at 250 - probably about 225 in the crossfire
185 degree fan switch
Mid-80's Coolant temperature switch
Port matched intake
3/8" CNC milled aluminum TBI spacers
Fuel pressure guage on front TBI
700R4 transmission rebuild to current standards when motor replaced
Power steering pump - last 4 months
Control valve - last year
Power steering pump hoses
Alternator and lower alternator bracket
"Specially designed" dual, free standing, K&N air cleaners with K&N lids
CVR Protorque high torque starter wrapped in heat blanket - NEVER have heat soak starting problems!
7 blade fan from a mid 70's - not the stock 5 blade
Master cylinder
Power Booster
All rotors and calipers (parking brake needs rebuilding - it drags some when you put on brakes and gives a squeeling noise some - traced it down to this, just have not done it)
Magnecor wires - $160 set - 6 months old
ACDelco Platinum Rapidfires
DUI High Output coil, cap and rotor
Dynamod
Windshield - about 6 months ago
T-tops, with new rubber, and the dot matrix liners Car does not leak at all, anywhere - unusual for a Corvette?
Tach circuit board - last summer
Sanyo radio with CD and tape - new one year ago.
Rear Antenna - last summer
Font speakers - have to look up brand - same time as antenna
Rear Alpine speakers - I would put in a booster, I think
Carpet
Door sill liners - have but not installed now
Thermal barrier under carpet, seats, tranny tunnel (over its top also), behind seats, trunk.
Not new, but a/c serviced all the time and will truly blow cold, and keep you cold even in the 100 degree summer days
Al Knoch leather seats
Poly differential donut - u-joints checked at same time, they are OK
Brand new BFG Radial T/A tires - probably 1,000 miles or less - in back. Front are about 1 year old. Show very little wear. Had total alignment done about 2 years ago.
New catalytic converter last fall - Car Sound high performance - flows better than Random Technology
Borla Mufflers
85 fuel pump
Viper alarm
Llumar Platinum metallic tinting
Looks like I need to continue with the rebuild - mahogany steering wheel next.
[Modified by Larry82, 7:28 PM 1/31/2003]
Old 01-31-2003, 08:11 PM
PatsLs1vette
PatsLs1vette's Avatar
Default Re: Looks like I'm not selling the 82 afterall (Larry82)
Larry,good thing, we were gone to have to kick some azz if you did. :jester
Old 01-31-2003, 08:29 PM
OHSIXX
Support Corvetteforum!
OHSIXX's Avatar
Default Re: Looks like I'm not selling the 82 afterall (patsnitrovette)
I know how it feels to sell a car and then wish I had it back, so my advice is keep yours. :steering:
To Looks like I'm not selling the 82 afterall
Quick Reply: Looks like I'm not selling the 82 afterall
