Question for you guys running a Holley 830 annular
Re: Question for you guys running a Holley 830 annular (Brettmc)
you just have to have a intake manifold that has tapped in plugs in the runners or plenum and buy a brass adapter at an auto parts store for 3/8th or what ever size hose. Any full vacuum source. Do not tree off existing lines like the power brakes etc.
Re: Question for you guys running a Holley 830 annular (gkull)
Brett :thumbs:
Because it would be like inducing a vacuum leak and a doubt if you headlight would come up very good.
I use a single plane and under the rear base of the carb is a tapped hole. Your right about an idividual cylinder would be slightly leaner if it is on one runner. but not to the extent of causing damage.
