'69 manual steering relay rod ball stud
Whew, what a mouthful. I'm in the process of tearing apart the front suspension of my '69 for a rebuild. I noticed that the front end kit I bought doesn't contain the ball stud for the relay rod that attaches to the pitman arm. Logically, I can't see why this part would wear, but looking at the boots they are cracked and in poor shape. Is there a method or measurement I can use to see if the stud has too much wear? Are the rubber boots available from a vendor without having to purchase the entire ball stud kit?
Obviously I haven't gotten the relay rod removed from the car yet, so some of this may be obvious once I get it off and on the bench.
Thanks,
Shannon
Thanks,
Shannon
Re: '69 manual steering relay rod ball stud (sb69coupe)
Shannon,
The "ball stud" does wear and usually these are worn out with a bad groove cut into them. The clamp and rubber boot are available, BUT I can`t seem to figure out why the boot is worth $12 ?? The ball stud (if you can find one) is terribly expensive. ZIP shows a kit for $95 in a two year old catalog but someone here was looking and said it`s discontinued. If anyone out there knows where to buy the "kit" to rebuild a manual center /drag link REASONABLE please let me know!! I just put my LAST good ball stud in my spare centerlink. redvetracr
Re: '69 manual steering relay rod ball stud (redvetracr)
Thanks! I found a kit in my current Paragon catalog. I'll call them today to see if it's still available.
Shannon
Shannon
I just rebuilt this part. I used the "kit" from Paragon. It comes with a stud,boot and clamp. About $50 if I recall. Doesn't come with springs or cups. The Zip kit was discontinued when I tried to order a month ago.
The ball stud was one thing that was overlooked in past suspension rebuilds and the ball had grooves worn into it. The GM manual has the correct procedure to install the nut and cotter pin.
Gary
Gary
Re: '69 manual steering relay rod ball stud (gtr1999)
Eckler's used to carry all the parts in the back "restoration" section of their catalog, but it's been about 3 or 4 years since I bought mine.
I would replace it while you're in there, just for good measure.
Jeff
Jeff
