Air cleaner replacement..PCV valve?
Alrighty, replaced the engine, and man that old thermostatic air cleaner makes it look like crud. So I bought a 14" Edlebrock chrome one- what do I do with the PVC hose comming out of my block? There isn't anyplace on the cleaner to attach it to. Do I just plug the hose? Oh yeah, emissions not an issue- she is exempt.
Thanks!
Thanks!
Re: Air cleaner replacement..PCV valve? (Captain_Kaboom)
You need the PCV.. The crankcase cannot vent with out it unless you use the valve cover breathers but you will get smelly blow-by oil vapors everywhere if the engine isn't perfectly fresh. There sould be a "knock-out" plug in the new air cleaner. PVC goes to manifold vacuum and the other side to the air cleaner.
[Modified by silvervetteman, 7:10 PM 1/30/2003]
Are you sure that the the new air cleaner didn't come with a plastic fitting to adapt the PCV to it? I haven't used an Edelbrock air cleaner but most of the after market units I've seen have had a knock-out on the aircleaner base for an adapter. If yours doesn't have one, it shouldn't be to difficult to do it yourself. Another option would be to use a valve cover breather and plug the vent from the block. In either case, you definitely need to provide a source of air into the crankcase.
I get it, but I guess I need another piece of PCV hose, 'cause my old one doesn't reach by acouple of inches..
