20x9.5 wheels will it fit????
DO you think a 20x9.5 with a 4.5 backspace will fit ? i have stock trailing arms
i have a chance to get 20x8 with 4.5 bs for the front and 20x9.5 4.5 bs for the rear but will they fit? the guy also has 20x8 for the rear (4.5 bs) if i can't
get the 9.5 to fit. help if you can
thanks :cool:
thanks :cool:
Re: 20x9.5 wheels will it fit???? (cruzin)
There are forum members that have gotten 4.5" backspacing with 9.5" width on the rear, thats with a 17" wheel and stock trailing arm. You may have to relocate your ebrake cable bracket to the top of the trailing arm. I don't know if 20s will cause problems in other places, it probably depends on the tires you're planning on using and your particular car's swaybars and spring setup. Good luck, and let us know what works. Hopefully we'll eventually get a tabulation of all the sizes that will fit with what modification. :cheers:
