Tremec - custom yoke
Ok all I have left to order before I start my install of the temec 5 speed is the rear yoke, which of course is unique for the vette. As I understand it - there are two designs (dont remember where i read this) anyway the question is - where is the best location to get this item.
This shouldnt impact the forum rules about posting for non supporting vendors as I dont think any of the supporting vendors sell this part - if there are, then who would they be, as I will buy from a supporting vendor.
As always, you guys rule - thanks.
Re: Tremec - custom yoke (fauxrs)
http://www.markwilliams.com/
The Yoke is called: C6 Take Apart Yoke...
:cheers:
Olivier
[Modified by GrandSportC3, 3:21 PM 1/30/2003]
:cheers:
Olivier
Re: Tremec - custom yoke (GrandSportC3)
You will also need a conversion U-joint.. The C6-Yoke is made for a 1350 series U-joint and the Corvette driveshaft for a 1310 series U-joint.. There are several u-joints available that are 1310/1350 conversion u-joints..
:cheers:
Olivier
:cheers:
Olivier
Is this the one you were talking about? the entry you described doesnt exist but this is a c6 yoke that can be taken apart.
Ford C6 31 Spline Rapid Release Transmission Yoke
I presume this requires one of those u-joints with differing size legs on the spider?
ooooops fast on the draw there----- :lol:
[Modified by fauxrs, 12:27 PM 1/30/2003]
:cheers:
Olivier
Here are some of the part numbers for the U-joint that can be used:
SPICER: 5-460X
Precision: 348
Rockford: K460
Neapco: 3-3140
:cheers:
Olivier
SPICER: 5-460X
Precision: 348
Rockford: K460
Neapco: 3-3140
:cheers:
Olivier
