speaker of 69-70 vette
anyone know what the ohms rating was on the std radio in the 69-72 vette, any other specs on the speakers? thanks. :confused:
Re: speaker of 69-70 vette (silvervetteman)
Yeah, 10 Ohms. I just pulled my front speakers out about a half hour ago. There's a bunch of numbers on the back of the speaker, but 10 Ohms is the only thing that's useful unless you need part numbers. Do you need a pair of original 1970 speakers? I can check to see if they work if you want. They weren't hooked up before.
Re: speaker of 69-70 vette (Scooter70)
scooter70, not looking for original matching stuff, my pass speaker just quit, what do you want for the pair if they are working ok?
Re: speaker of 69-70 vette (LT1driver)
You can get an upgraded replacement speaker of your choice in the correct size at any audio shop and add a resistor. You may even find an 8 ohm speaker that will work fine. 68-69 kick panel mounted speakers are 4 X 10. Under dash speakers used from 70 on are 4 X 6.
[Modified by Scooter70, 10:02 AM 1/31/2003]
