HELP!!! Clutch Pedel Z-bar Removal Stuck need help ASAP!!! 4-speed'ers
I am trying to remove the zbar to install my headers and I am stuck!!! :banghead: I un screw it from the block and it gets real loose
and wables around but wont let go. I screw it all the in to the block and and it
gets real tight so it seems screwing it out is right but what am I doing wrong
help me please I am freezing and flustrated :cry
Re: HELP!!! Clutch Pedel Z-bar Removal Stuck need help ASAP!!! 4-speed'ers (mountainshark76)
Oh man, it's been a LONG time since I took mine out or put it back in but...
I think there's a c-clip or other retaining setup that holds the Z-bar to a ball stud. There are ball studs and bushings all around the clutch actuation stuff, I can't recall what is where...
hope someone can help ya soon!
Jeff
Jeff
Re: HELP!!! Clutch Pedel Z-bar Removal Stuck need help ASAP!!! 4-speed'ers (no_radio)
have you removed the nut on the other side?Its a 9/16" nut.If you have removed it,it should just pop right out..
Or have i missed something? :smash: :cheers:
maybe its diffrent on a SB
[Modified by BB wowbagger, 7:50 PM 1/28/2003]
Re: HELP!!! Clutch Pedel Z-bar Removal Stuck need help ASAP!!! 4-speed'ers (BB wowbagger)
Yes it is the same on a small block. Undo the nut on the other side and you do not have to remove the ball stud from the block. Once the nut is off teh Z bar slides up and off teh ball stud and out of the car.
Re: HELP!!! Clutch Pedel Z-bar Removal Stuck need help ASAP!!! 4-speed'ers (Gordonm)
John
THANKS is not enough two seconds after you guys posted I was good to go
thank you my brothers :cheers:
