Headlamp open sensor
My Headlamp light on the center console comes on when I turn the lights on.
I am suspecting one of the "Open" sensors is bad. Anyone replaced one of these?
Re: Headlamp open sensor (Stewart's74)
You shouldn't have any trouble finding them, but make sure you are sitting down when you check the prices though :cry . I think I paid around $40.00 each for them. :eek:
It probably broke.
You have one on each headlight. One nut and they are off.
Most of the venders carry them, about $25.
If you unplug the broken switch, the light will go out.
Hope this helps.
Terry
[Modified by trw, 10:05 AM 1/28/2003]
Hope this helps.
Terry
Re: Headlamp open sensor (trw)
My right hand one was broke when I bought my car. The switch works but the plastic threads were snapped off. A couple of ty-wraps later and everything works. I ty-wrapped the switch closed and ty-wrapped it out of the way.
John
John
Replace switch is about $25. When one of mine broke I just unplugged the wires and tie them up out of the way. Once I removed the switch the lamp housing was very hard to close - The switch prevented the linkage from going another 1/8" which put the linkage in a bind. I just put a section of rubber hose over the end of the stop and the light raises and shuts fine. Yes, I know its a bubba.
Roger
Roger
Looks like I got ripped when I replaced mine, Zip has them for $19.50 http://store.yahoo.com/zipproducts/zip-es-312.html .
Oh well, live and learn.
:D
:D
